Threads: 79
As eurotec is drawing near, the delorean has decided to be naughty. Today the delorean wouldn't start when hot. It did eventualy after a lot of cranking and then spluttered into life running on a couple of cylinders until it sprang back into life properly. It did this twice when I had left it for a short while (30 mins ish), but as a test I turned it off and back on again about 5 secs later and it fired up perfectly. Am I right in thinking these are accumulator symptoms? ie loosing pressure when left for a while.
If so, can they be repaired or is it a case of ordering one up from Ed or something?
Threads: 79
Sweet sounds like a plan
Want to be sure before I shell out 80 quid
I'll bring my volvo venturi with me too as I STILL havn't had chance to fit it so there might be time to do it at the event. Could you bring your CO tester too? In exchange for another beer?
Threads: 813
NickT Wrote:Ok I'll bring the gastester too.
Boy this bloke loves his beer :lol: (nearly as much as me :lol: )
Threads: 55
NickT Wrote:Sounds like accumulator.
Just replace.
ps I can do a fuel pressure test for you at eurotech to confirm this or not, in exchange for beer
hay nick can i also bribe you with beer and get you to test mine aswell at the same time it seems our cars must be twin sisters as it is doing the same thing?
cheers mate Tyson
Threads: 79
Hi Tyson,
Its a bloody pain isn't it. I thought it wasn't going to start this afternoon, then it finally coughed into life but it was running on 2 cylinders or something for a few seconds, it was shaking about and sounding horrible then a bit of a rev and it was fine again. Worrying moment
Threads: 79
hana 5284 Wrote:it seems our cars must be twin sisters
Well they do have each others speedometers so kind of related :wink: :lol:
He likes his gravy too........
Threads: 81
could it be related to the fuel injectors too??
Kind Regards,
John [DOC No. 8]
Threads: 79
I doubt its injectors becuase when its running it purrs perfectly. When I get home from work I'll push the flap down and see. That will be about 24 hours since it was ran last, is that too long or should there still be resistance?
