14 May 2008, 00:08
Hi-ya all, I've been chatting with my old mucker stinky Tony and heard that their are an increasing number of members with metering heads that have gone pete tong. I stripped one down tonight after Tony tried it on his car a couple of weeks ago and he said that only four injectors were working out of the 6, so I figured if it was knackered I would strip it down and if I couldn't resamble it properly it would be no Biggy.
They are infact very simple, and very clever and manufactured to a high spec and tolerances inside, their are seals in their but they were fine, and the control plunger has no seals at all, it is just a ground metal piston in a sleeve. And the fuel ports are to small to be machined so they were probably spark or wire eroded at manufacter. I suspect the problems with these heads not working properly is lack of use, I.E. fuel tarnishing and corrison or rust which could block these fine ports and hinder the main control plunger. I have managed to source a rust remover that will not damage the seals and left to soak for 24hrs could restore the metering head to it's original intergrity. I have checked a couple of US sites and although they can supply refurbished units, I suspect that all they do is exactly what I have just explained, and that is to strip them down and clean them. Bosch do not make a service kit because I've checked. The first picture is curtisy of Special T, but the second picture is one I took tonight after I stripped it down. My point being is, they are so simple their is nothing to stop it working properly unless it is contamined with either rust or fuel tarnishing or debris.
Regards Jay Monk
VIN: # 3928
VIN: # 4989
VIN: # 3928
VIN: # 4989
