18 Nov 2006, 14:05
To all,
With the recent downtime of the current ISP it has been decided that the harmonisation between the current forum hosting and the www.deloreans.co.uk will be rapidly brought forward (, as noted in the AGM at the NEC)
The transfer will be done this afternoon from 14:30 and should be active before 19:00 if all the export/ reimport SQL data transfer goes to hand.
The majority of the work has been done in conjunction with myself and Tristan last night and this morning to minimise disruption with this hopefully seamless transfer.
The new forum will work in the same way as before.
ALL data will be transferred which is why this forum will be locked/ closed down during this short interim.
Once the forum is back up please let us know if something has been missed using the Forum Error Reporting Forum or email me at
NickT@ukdmc.co.uk (this email will be active for 2 weeks after this post has been posted)
Please be constructive in your errors giving as much detail as possible.
Once this is up and working we would be grateful if you could update any links in your favourites or personal web sites to reflect this change.
Thank-you in advance for being patient.
