Standar manual transmission with V8?
I'm worried that the standard delorean transmission isn't strong enough to cope with a 350 small block V8 what do you think?
Well troy as far as i know the Ford RS 200's run the same gearbox and easily put 300bhp through
Cheers Tony TT
Thanks Tony
The RS00 is mid-engined 4WD AFAIK... You might get replicas running a UN1.
The problem is aligning the input shaft properly. I can do a gearset and impit shaft for it for around £2k which will make it good for over 500hp
You know I feel DMCL are becoming a better company than DMCH I haven't looked at your site in ages but I'm really impressed with all the upgrades you offer and the performance options are amazing. DMCH seem a bit behind when DMCL look like they're looking more into making the Delorean a modern car.
Congrats on the awesome website and company.
The problem with the un1 is not bhp its tourqe that breaks the input shaft and the fifth gear .And a v8 has lots of torque
Regards Paul O'Malley
DOC 253 South of Ireland Rep
