30 Oct 2006, 18:17
The most recent DeLorean I have driven other than mine was Dan Shane's (now sold) and this showed how when set up correctly you can have a brake pedal that is as responsive as a modern car.
My car brakes very well but I have around an inch of travel before anything happens. After that the communication from the brakes to your foot is spot on from a responsiveness point of view.
This is my current setup:-
- I have Ed Uding's vented disc's and Kevlar pads on the front (the rears are stock)
- DMC Ltd re-manufactured front Callipers (silver finish opposed to the now defunct Cadmium finish still showing on the website) cured the brake judder that had gradually appeared over recent months.
- DMC Ltd Stainless brake hoses. Stainless versions are supposed to cure the swelling as per the OEM's although I have never experienced any swelling from the OEM's they were 25 years old and would affect my braking performance at some point so I felt it would be worth while to update whilst the system was re-bled from the previous weeks fitting of new callipers. So far I can feel no difference, but sometimes until you replace something you cannot tell if the old part was still spot on or not.
The Brake Master Cylinder and servo have not been changed in my near 5 years of ownership (could be original). I am guessing that the rod from the Brake Master cylinder to the brake pedal could do with adjustment. Otherwise apart from changing the two afore mentioned parts I am fresh out of ideas (and cash).
The system is completely air-free and the BMC is not leaking. I have good continuous travel to the carpet and when sat at rest the brake pedal is flush with the clutch pedal.
To recap, although braking is spot on I am looking for instantaneous braking when I first depress the pedal not after it has travelled an inch... I guess this can be described as spongy. As these cars have no ABS, that extra 1" delay time could cost me when it matters most...
I will be fitting a set to mine before too long because I did succeed in overheating mine recently on a 3 mile stretch of country lanes that I know well, and I wasn't trying particularly hard.
