18 Oct 2006, 12:47
Hi all,
I've been given a scrap Cavalier 2.0GLi, which amongst having nice things like leccy windows and mirrors and a nice velour interior (which I'm gonna fit in my 1.6L), it also has power steering.
I'm hoping to remove the rack, pump, and ancilliary items, but the GLi has a different lower pulley to run the belt for the PAS.
My Cav, being a 1.6, does not have this belt - I've been told that the early 1.6's like mine were never designed to have PAS fitted hence why they have a different lower pulley.
AFAIK, all the 4cyl Vauxhalls had pretty much the same engine blocks - I've compared the engine castings and mine has the same mounting points for the PAS system as the 2.0. So, do you think it will just be a case of changing the pulley (along with all the other bits) to fit PAS to my car?
This also kinda got me thinking about PAS in the DeLorean, because obviously the RWD/Rear Engine set up would not facilitate this sort of PAS set up.
Any advice gratefully appreciated.
Cheers!
Cheers!
