24 Feb 2007, 19:08
Hey Everyone
Every time I turn on the heating/air con fan there's an extreemly unpleasent loud screeching sound coming from the fan. I'm going to try to aid it by taking opening up the fan casing (under passenger side of the dash) and giving the fan bearings a good dose of WD40 and or grease depending on what seems to work best. Is there anything I should look out for when doing this or is it fairly straight forward to assemble/reassemble the casing?
Cheers!
Cheers!
Scott Miller
DOC 279, Vin 2107, Manchester
http://www.makecollective.co.uk
http://www.manchester.ac.uk/b15workshop
As I hardly ever use the car I dont think a full motor replacment is in order, so this will do for now.
