Rear Fog Light
Bad luck..... No one will ever guess!
Chris Hawes Wrote:wiring up the foglamps like this used to be in the members area of the club website I think...
Restored from backup.
http://www.deloreans.co.uk/members/tech ... ights.html
I would personally wire it using diodes and solder/crimps, although the write up may have been updated since my latest backup.
I wired mine using this:
http://www.dmcnews.com/Techsection/eurolites.html
any particular flavour of diode we should be looking at? :lol:
I've looked here:
http://rswww.com/cgi-bin/bv/rswww/searc ... &Nr=avl:uk
- Dave Smith
VIN: #00944 DOC: #535
VIN: #03193
I just used mains 13Amp 230v ones as I had some of these of my shelf.
Nick.
NickT Wrote:I just used mains 13Amp 230v ones as I had some of these of my shelf.
Nick.
Are you sure these weren't the 3 phase 415v type?
hahahahahhahahaha!!!!!!!!!!!!!!! :lol: :lol: :lol: :lol: :lol:
love the new avatar Nick!!!! Big Grin
Hey, with Hallowe'en coming up, you could do an extra special scotchlock, after all, they might as well have come out of satan's ar$e! :lol:
Big Grin
old thread, but never mind -
I'm going to use the lambda light for a fog tell tale. Does the light have to say 'fog' on it or have the rear fog symbol on it? or does it just have to light up when the fog light switch is depressed?
- Dave Smith
VIN: #03193
Barson Wrote:old thread, but never mind -
You will be ok with that light coming on when the switch is depressed ... thats all the MOT standard says .
thx
- Dave Smith
VIN: #03193
Yep mines like that too, its just spliced in so the lambda light is still connected to the counter but also comes on with the fog lamp.
The wiring should really have a diode to prevent the voltage from the lamp back feeding into the fuel computer (, unless of course the computer is not used anymore and has been disconnected)
presumably that's only if i retain the lambda light facility and only splice in the fog switch, rather than disconnecting the lamp from the counter and connect it up to the fog switch.
- Dave Smith
VIN: #03193
Thats right.
