26 Sep 2007, 13:22
Barson Wrote:which car is that?
it's not the one at that motor museum, is it?
Yes its
http://www.deloreans.co.uk/forum/viewtopic.php?t=655
WTD: Full set of headlights.
26 Sep 2007, 13:22
Barson Wrote:which car is that? Yes its ![]() http://www.deloreans.co.uk/forum/viewtopic.php?t=655
26 Sep 2007, 18:08
this is the connector i was talking about:
looks to me like a side light holder.
- Dave Smith VIN: #00944 DOC: #535 VIN: #03193
26 Sep 2007, 18:23
because it is.
wonder if it'll fit in the brackets at the back.....hmm
26 Sep 2007, 19:09
I think its the fitting it in thats the problem .... maybe take a look and let us know
26 Sep 2007, 22:55
Barson Wrote:because it is. I threw mine away and stuck a bit of shaped Stainless steel over the hole! Chris
26 Sep 2007, 23:21
Barson,
The hella lamps pictured will fit as these are exactly the ones which are fitted to my car. They do however require modification of the buckets and also as I recall the inner headlamp brackets themselves. This didn't matter to me as I was having mine sandblasted and powdercoated anyway. It's a bit of work- I did all of mine in an evening with a selection of files, a 1mm cutting disc for a 4" grinder and some patience. It's a matter of preference really, but I preffered matching Hella lamps and was replacing all 4 anyway- I prefer the look of them to the Halo ones but thats probably just me. I think they are more original looking. Here is a recent picture of them installed-best front pic I have.(watermark is because a newspaper photographer took pic and I have to buy it from him if I want it) ![]() Let me know if you want them and I can hunt out the part numbers for the matching inner lamps (main beams) Stephen #10213
01 Oct 2007, 21:20
hihihihi.
removed my outers tonight. the buckets are in decent enough nick. little rust and a small wasp nest on the driver side. I tested the new hellas in the buckets. i can see myself how much they don't fit ![]() I'm going to cut me a hole and try and get these blasted and powder coated. stevie, dude, where'd you powder coat yours? was it a local supplier? Dave.
01 Oct 2007, 22:44
Hi Dave,
Crap, sorry- I was supposed to get back to you, been crazy busy. Yeah, I sand blasted them myself and had a local crowd powder coat them; it cost pittance- around 20 euro from what I remember. All I can advise you is take your time with them and dont cut too much away at a time. The 1mm cutting disc is a deadly job and finish them off nice with a few different files. Drop me a pm if you have any other questions. ![]() Stephen #10213
12 Oct 2007, 18:17
if anyone's interested, I've got the side lights wired up and running:
the new harness: the taps: i took the opportunity to, whilst i was in there, to modify the ground on the front side fender to give me a flashing side fender. all works!
12 Oct 2007, 18:29
Well Done matey !!
( Just one thing ... get shut of those scotch locks before NickT sees them ![]() ![]()
12 Oct 2007, 18:33
fecking scotchlocks............... the cause of my 'intermittent' side lights.... grrrr...... bloody things should be banned.
Soldering properly and sealing with heatshrink is much better and also looks better (IMHO :wink: )
Jul 1981 DeLorean - Flopsy #2292 Aug 1989 Cavalier 1.6L - Guinney Oct 1994 Twingo Mk1 - Freddie le Grenouille #170
14 Oct 2007, 12:11
Nooooooooooooo, not scotchlocks !
14 Oct 2007, 13:16
..oh dear ...He has seen them !
14 Oct 2007, 16:12
calm down dear, it's just a screw up.
![]() i re-did it all with solder and patience yesterday morning. ![]() all works! pain in the rear with my weedy 25w iron :/ (maybe it's just me)
14 Oct 2007, 16:22
LOL
![]() Good work matey. |
« Next Oldest | Next Newest »
