Threads: 79
Hi
I'm after one of these.
It's the line that goes from the top middle fo the fuel distributor to the CPR (14mm fitting).
I'm after the NOS version if poss with fittings attached
cheers
Dave.
- Dave Smith
VIN: #00944 DOC: #535
VIN: #03193
I'll have a look in my garage tomorrow
Threads: 812
If Nick cant help you out I may have one spare,
Threads: 79
thank you sir, thank you sirs.
don't know why I keep calling it a CRP.
I MUST BE FIK OR SUMINK!
cheers
Dave.
- Dave Smith
VIN: #03193
Threads: 73
im sure i have one as well, we will get there in the end TT
I've had a look and I haven't got one.
I did have one but I used it to fix my second fuel pressure gauge.
Threads: 73
right best i look, will get back later TT
Threads: 79
thank you gents. 8)
I need this so I can properly test the CPR so I can diagnose it as causing all the problems I'm haivng with my engine. Spluttering/slugish acceleration/backfiring....
I managesed to plit the original line and since I've 'repaired' the line it leaks... :roll: I'm good at this!
choke choke....
thanks very much.
Dave.
- Dave Smith
VIN: #03193
