17 Nov 2014, 22:12
I know about the vent tube, but where does it vent to? Inside the filler neck?
Before I put fuel in the tank ( it's been drained for a year), I tried pressuring the tank by removing the fuel cap and blowing air into it.....
Needless to say, a slight hissing could be heard and the pressure would drop.
Is this normal, or is it leaking at the boot, sender, or filler? There is a fair amount of resistance when blown into, but it's not totally sealed.... Then again, if there was no vent, surely the tank would collapse as the tank was draining?
