21 Apr 2014, 01:53
Wooden DMC build
21 Apr 2014, 02:04
work begins on Y frame chassis front part...
front frame put together trying to come up with solution to strengthen weakest points of frame trying to come up with something that will control my wheels bottom shelve added for complete support wheels test fitted edges to be cut and rounded so that wheels can move moving perfect adding more detail on sides for extra strength of the frame parts steering system test fitted and in place...test fitted to frame just for looks.... next time will try to marry both frame parts together
21 Apr 2014, 09:02
That really is superb work, hats off to you sir!
22 Apr 2014, 00:43
Chris Williams Wrote:That really is superb work, hats off to you sir!thank you sir :wink:
22 Apr 2014, 02:22
arms to be done to steer wheels
both in place tiny part of wood added on top of arm for extra strength part to join track rod end added both sides of wheels hooked up, steering rod/bar joined, test fitted, works perfect front frame temp fixed on body so it can be married with the rest of Y frame checking gaps in wheel arches and frame position in front....OK, just like the look of this :driving1: wheels sits perfect all around, its time to have one proper Y frame chassis creating base plate that will join both frames permanently together, in real life I guess it's called fuel tank closing plate wood strips glued together and sanded, ready to be attached when was removing complete Y frame chassis decided to remove front luggage compartment and make it better after steering is sorted out adding extra strength and extension to steering wheel so it can reach front steering mechanism decided to add extra support for steering column, in meantime created extra DMC signature at the front, it will be barely seen when front luggage compartment will go in, looks cool tho support wall installed cutting to add steering done and working, small tweaks and details to be added to permanently finish watch video to see steering in action http://youtu.be/QpIvW9VBPNM
22 Apr 2014, 09:45
That is so impressive, you really do have a very special set of skills....!!
22 Apr 2014, 22:55
malcy34 Wrote:That is so impressive, you really do have a very special set of skills....!!cheers :wink:
22 Apr 2014, 22:56
23 Apr 2014, 08:34
The level of detail you are putting into this is awesome!
DOC 649 ex DOC 562
23 Apr 2014, 12:35
MikeWard Wrote:The level of detail you are putting into this is awesome!thanks MikeWard, trying my best to accommodate needs of woodworking art, scale of model and detail of Delorean
24 Apr 2014, 20:39
Truly amazing craftsman ship!
Just one small point, there's way too much lock on that steering :lol: :lol: (j/k)
Richard H. DOC 365 VIN 1274
26 Apr 2014, 01:51
for past few days there was good few trials and errors on front lights. Wanted to get best possible result of the looks of the front lights.
So here it goes... Started with this, my good old friend Arthur Guinness came in to workshop to give us a hand on project it got cut in pieces made some clever tool did some mirror shine polishing used my new cool tool and hammer to make some cool stuff and I have shiny reflectors for my lights looking good time paint background black clear plastic saved from flowers used for glass imitation...lines cut with paper knife vola, 2 lights done so far will be adding another cool feature here's lights in action with dimming control https://www.youtube.com/watch?v=wlPIwfe-7e0
26 Apr 2014, 09:16
The level of detail is amazing, love the lights!
27 Apr 2014, 08:27
Cheers Chris :wink:
both lights in before wiring front lights need to sort out trunk for space first panel goes in back wall of trunk goes in sides and floor...with correctly positioned spare wheel space...front wall to be added...all to be primed and painted in glossy black paint and few more details to be added
27 Apr 2014, 10:29
I love seeing the progress on this.
After you have finished it, you defo need to get a full size delorean |
« Next Oldest | Next Newest »
