Any one else thinking of doing a BTTF conversion?
#46
Oops, my apologies. Its not that one, I actually went with these!
[Image: an4-ss-ptfe-95mm-3-8-id-blue-billet-alum...77-i95.jpg]
http://www.deloreanhire.com
Wow... They look far superior! The previous ones look like regular motor factor cable/pipe clamps, but with a bit of colored sheath slid over them... Pence to produce, I guess you are paying for the colour.
Good find!
My interior prop collection is now coming on. One thing I am having problems with is the interior hose. (The black/orange stripped hose) that runs at the side of the Clare box to the front of the car. Although I have found a similar colour it doesn't look quite right. Can any one point me in the right direction of the correct coloured pipe?
Mike
Bingley, West Yorkshire
VIN 2493
"Hey you, get your dam hands off her"
TheOriginalMrP Wrote:Wow... They look far superior! The previous ones look like regular motor factor cable/pipe clamps, but with a bit of colored sheath slid over them... Pence to produce, I guess you are paying for the colour.
Good find!
Cheers! Took a while, a company in the US had a load spare but had to make phone calls and be polite, emails don't work :wink:
Thanks do you happen to have a link for the site where the cat hose it is sold?
Mike
VIN 2493
I would hope modern lighting technology could improve on the neon tubes, they're fragile and on close inspection obviously a separate lighting effect (as opposed to corona discharge on the bands themselves, if they were real field emitters). Matted EL wire or panel might be able to do it if overdriven to 1000 Hz or so, the brightness has improved a lot over the last decade. LEDs definitely get the brightness but the trick is diffusing enough to avoid the fairy lights look. Well designed LED tubes should at least improve the durability and power consumption. A dense grid of tiny surface-mount LEDs on the back side of the flux band metal should be even better; the light would be diffused by the reflection off the grained stainless panel. Would be incredibly time consuming to assemble though.
bttf car Wrote:The neon's are led they rum at around 3 amps for the whole car, very flexible and will never break
Ok but that's an LED tube then, not a neon tube.
http://www.ebay.co.uk/itm/Back-to-the-f ... 4246192?pt
For any one who is interested in a working GPS bttf speedo. This is currently a bargain with two days to go Smile
Mike
VIN 2493
These will go very nicely in my collection. Lucking forward to the warmer weather to start the interior conversion. (No holes drilled version Big Grin ) just need some red paint for this prop!
Mike
VIN 2493
That's awesome mate! Those clocks are hard to come by now! Is the tank plastic? If so, I'll prep and prime it for you if you need?
Thanks Luke, that would be great.
How ever it's made of metal, I could do with your help putting it all together at some point Big Grin just got a load of the interior cat hose from USA. Postage cost more than the hose itself. Sad
Mike
VIN 2493
Deloreanyorkshire Wrote:Thanks Luke, that would be great.
No worries. I'll pop up at some point when you can be bothered. Aye, you'll find the same with most parts needed for the conversion. When, cough, I mean...IF you decide to add p clips for your external wires, my Bosch is charged up and I can get you the purple clips too :lol:
Wow that's what I call expensive hose. Just bought 10ft of cat hose for the interior of delorean. $90 including postage and then get taxed £25. I don't know how that worked out but ended up paying £70 approx for a bit of hose that turned out to be good quality but too thick (incorrect) Sad Who said an interior time machine conversion would be cheap?
Mike
VIN 2493
Deloreanyorkshire Wrote:Wow that's what I call expensive hose. Just bought 10ft of cat hose for the interior of delorean. $90 including postage and then get taxed £25. I don't know how that worked out but ended up paying £70 approx for a bit of hose that turned out to be good quality but too thick (incorrect) Sad Who said an interior time machine conversion would be cheap?
Definitely not me! :lol: By far the most expensive, but most rewarding part.
The exterior hose is around £100 for 10metre too! Let mW know when you get to this and I'll show you where I got it Mike.
Thanks Luke. I'm sure it will look great in the car but just wished I had bought a smaller tube as this one is slightly bigger than what it should be.
Mike
VIN 2493
