Wooden DMC build
now, seat base for both sides drawn and made Wink
[Image: 25052010.jpg]
picking up wood with grain is cool part of the seat build...just as picking up fabric for seats Smile
[Image: 25052011.jpg]
cut out and sliced in two identical parts, curve line marked for shaping
[Image: 25052012.jpg]
shaped
[Image: 25052013.jpg]
one shaped other to go
[Image: 25052014.jpg]
both shaped, sides next in line
[Image: 25052019.jpg]
shaped, more marks, more shaping
[Image: 25052016.jpg]
base finished, looking good
[Image: 25052017.jpg]
next...sanding down floor to match proper height to fit in back part of the seat
[Image: 25052018.jpg]
dude, thats totally awesome, you have too much skill. keep at it Mr Green i used to be a model and mould maker, mainly building slot cars, RC cars, and HO buildings, and Latex and vac formed moulds for customers at the model shop i worked in.
theres just one big problem i see about your model.....
the fact that i didnt make it, lol Cry
RobScott Wrote:dude, thats totally awesome, you have too much skill. keep at it Mr Green i used to be a model and mould maker, mainly building slot cars, RC cars, and HO buildings, and Latex and vac formed moulds for customers at the model shop i worked in.
Big Grin thanks for that RobScott. Love to make models from wood simply for one reason, there's no rules as it's piece of art. I make it my way and I love it Wink
stay tuned Wink
some more sanding done on floor Big Grin
[Image: 26052010.jpg]
glove box added to dash panel
[Image: 26052011.jpg]
and opens
[Image: dscn4711.jpg]
backs of the seats done, headrests left
[Image: 26052012.jpg]
[Image: 26052013.jpg]
left hand side panels added to dash
[Image: 27052010.jpg]
tiny piece added by speedo board
[Image: 27052011.jpg]
another panel added along with tiny right hand side panel by speedo board
[Image: 27052012.jpg]
window frame painted
[Image: 27052013.jpg]
dashboard test fitted
[Image: 27052014.jpg]
some stuff under dash painted
[Image: 27052015.jpg]
side panel of the dash added ( don't mind paint job Big Grin )
[Image: 27052016.jpg]
steering wheel on the way...2 panels of wood glued together fir strength
[Image: 27052017.jpg]
sanded and marked
[Image: 27052018.jpg]
hole made
[Image: 27052019.jpg]
sanded
[Image: 27052020.jpg]
building middle part of the steering wheel from 4 tiny parts
[Image: 27052021.jpg]
[Image: 27052022.jpg]
complete
[Image: 27052023.jpg]
side vents for dash added, steering test fitted, dash test fitted, seat test fitted
[Image: 27052026.jpg]
[Image: 27052025.jpg]
some flooring going on here
[Image: 28052010.jpg]
[Image: 28052011.jpg]
gear stick cover made from black insulation tape
[Image: 28052012.jpg]
[Image: 28052013.jpg]
[Image: 28052014.jpg]
[Image: 28052015.jpg]
putting reclining seats together, few more bits to do
[Image: 28052016.jpg]
level rails on, not for moving seat, just to level it and keep it in place
[Image: 28052017.jpg]
test fitted
[Image: 28052018.jpg]
switches by steering wheel in progress
[Image: 28052019.jpg]
[Image: 28052020.jpg]
painted and on....peace out Big Grin (see shadow)
[Image: 28052021.jpg]
Sir, you are a genius!
Dashboard excellent,
Reclining seats excellent,
Steering wheel goes one better, I thought that was the limit...
Then I saw the indicator stalks!!!
Rich Hanlon Wrote:Sir, you are a genius!
Appreciate that "Sir" and I'll take first three Wink
Indicator stalks look better with naked eye Wink
I meant, as in, they're one level better, I can't believe the level of detail you are going to!
Rich Hanlon Wrote:I meant, as in, they're one level better, I can't believe the level of detail you are going to!
it's addiction or suntin, I just wanted to throw in simple plain dash with steering, ending up now kitting out whole interior Big Grin
headrest drawn up
[Image: 29052010.jpg]
done and dusted
[Image: 29052011.jpg]
fits perfect
[Image: 29052012.jpg]
fitting magic piece(thick rubber) so the reclining seats pop back when no pressure on to them
[Image: 29052013.jpg]
rubber strip fixed under the seat
[Image: 29052014.jpg]
back
[Image: 29052015.jpg]
and back up..works perfect
[Image: 29052016.jpg]
preparing door upper surface to apply extra wood for extra strength
[Image: 28052022.jpg]
wood sliced/cut in pieces ready to be glued on to door
[Image: 28052023.jpg]
all pressed together with clamps for strength
[Image: 28052024.jpg]
glued now, ready for sanding
[Image: 29052017.jpg]
[Image: 29052018.jpg]
done and dusted
[Image: 29052019.jpg]
my first love waiting to be started Smile
seats from DMC fits OK Big Grin
[Image: 29052020.jpg]
[Image: 29052021.jpg]
[Image: 29052022.jpg]
Awesome work! 8)
http://www.deloreanhire.com
@ lukebrynycz - thanks Wink
decided to chop off upper part of rear to rebuild it with straight parts
[Image: 16012010.jpg]
could be pick up truck DMC Big Grin
[Image: 18012010.jpg]
after some sanding new panels glued on
[Image: 18012011.jpg]
and after sanding looks better
[Image: 19012010.jpg]
more panels added
[Image: 19012011.jpg]
and more
[Image: 20012010.jpg]
[Image: 20012011.jpg]
both sides complete, looking good
[Image: 20012012.jpg]
time to straighten the roof
[Image: 20012013.jpg]
middle and front panel added on top of existing frame for extra strength and sanding
[Image: 20012014.jpg]
roof top sanded down in one level
[Image: 20012015.jpg]
doors open and close perfect
[Image: 20012016.jpg]
[Image: 20012017.jpg]
Indian mahogany block getting ready to become rear fascia on my DMC
[Image: 21012010.jpg]
temp glued on for part picture visualization
[Image: 21012011.jpg]
drawing up some guidelines
[Image: 21012012.jpg]
top and sides cut off
[Image: 21012013.jpg]
starting to sand, cut and carve out space for lights
[Image: 21012014.jpg]
after a while getting there
[Image: 21012015.jpg]
and after another while, test fitted to see if lines match etc
[Image: 21012016.jpg]
temp engine bay cover cut out to see if everything matches
[Image: 21012017.jpg]
lights cut out, more room made for them
[Image: 21012018.jpg]
test fitted
[Image: 21012019.jpg]
