07 Apr 2013, 21:17
Hi all
I have spent some months with the heater box removed from the car and in effect has to replace the evaporator seeing as I was already in there.
When reconnecting the evaporator I used new seals etc but the pipes were at different angles to the originals and that made reconnecting the accumulator tricky without cross threading the nuts... theres just no room for movement under there.
Anyway its all back together and just to emphasise that when I bought my car 7 years go, the a/c cycled a lot but it did work. As time went on it stopped working but I did have it charged with a mickey mouse aerosol can which made it work for a brief time afterwards. The system still had pressure in it before I removed the evaporator and it appeared to have green anti leak detection dye in the system too....
However there was a small split in one of the hoses that attached to the accumulator... I guess it was one that ran to to condenser at the front but not entirely sure....
The split was superficial and appeared to have an internal braided hose inside... which is probably sealed internally too. I dont want to have to replace this unless absolutely neccessary and there was no evidence of leakage there...
Ok to go ahead and have a recharge and a leak sealer additive with the pag oil?
She was running 134a before though I dont know if Chriss Spratt did any upgrades to make this totally bulletproof..
