01 Apr 2007, 17:08
oh dear.
Still having problems getting this puppy to run. Initially I thought this was a fuel issue, but I'm doubting that after I tested the coil:
I took a spark plug out and tested it on ground and only got a small spark. Nothing that would set your pants on fire, that's for sure.
I then connected a spark plug up to the coil directly and only get a small spark (definitely not large or big enough to see if it's blue...)
Set my multimeter thing to terminal 15 on the coil and to the ground and it reads 4.5v.
The coil is the blue one (bosch 0 221 122 001) ...assuming it's the original.
Any ideas would be appriciated.
cheers.
Barzo.
cheers.
Barzo.
- Dave Smith
VIN: #00944 DOC: #535
VIN: #03193
- Dave Smith
VIN: #03193
