10 Jun 2010, 10:29
This might be something that Rich Hanlon could have a look at, as he deals with metal fatigue as part of his job - might be worth having a chat to him - he might be able to assess the failed ball joint(s) and let you know.
This next part is a bit OT, but in a way echo's what Chris was saying. We brought the Avantime out of storage last year to put her back on the road (and get the LPG conversion done), and she went into Renault for a 36k service and MOT. At this point, the car had done 32,000 miles in 7 years, so nothing really for a modern car.
We were told that she'd failed the MOT on play in the steering arms. Apparantly a common failure on Espace's (the Avi is based on the Mk3 Espace) and on Laguna's. We'd noticed a 'bump bump bump' when going on full lock, for instance when manouevering in a carpark, but didnt realise what it was. On the Avi (and Laguna and Espace), you cannot just replace the steering ball joints at Renault, you have to replace the whole lot, arms and all, at £300 a pair
(plus fitting of course). There was that much play in the arms that you could wobble the front wheels back and forth!
Also, this is a problem that in the main only affects the 3.0 V6 Avi, not the 2.0 Turbo apparantly due to the wheel sizes - the 2.0 Turbo has 16" rims, the 3.0 V6 has 17" rims that are also wider - with the option of 18" wheels too (they look the mutts nuts 8) )
(plus fitting of course). There was that much play in the arms that you could wobble the front wheels back and forth!Also, this is a problem that in the main only affects the 3.0 V6 Avi, not the 2.0 Turbo apparantly due to the wheel sizes - the 2.0 Turbo has 16" rims, the 3.0 V6 has 17" rims that are also wider - with the option of 18" wheels too (they look the mutts nuts 8) )
![[Image: ccf11_4.jpg]](http://pardo.net/bike/pic/fail-009/ccf11_4.jpg)
