Parts Available from within the club (Dave Howarth)
These are some of the parts available from Our Club President Dave Howarth. He is based in Manchester and can be contacted on; 01942 882331 or his contact details are in the club magazine.
Please note that this list is not a full list of the parts he has or can get, it is just a guideline. It is always worth contacting him to double check as he may well have or can source that elusive DeLorean part!
Reconditioned items;
Starter Motor £75.00
Alternator £75.00
Water Pump £80.00
Steering Rack £85.00
Ignition lock barrel & Key £20.00
New Parts;
New and Unused Chassis for Auto £2500
Unused under body £1200
Petrol Tank(s) £50.00
Headlight’s (UK spec) £85.00 pair
Track Rod Ends £11.00 (each)
Glass for Rear wing panel £60.00
Rear wings £300.00
Rear Facia £300.00
Front Facia £260.00
Headlining fabric £30.00 (per car)
Washer Bottle motor £10.00
Door rubber seals £49.00
Oxygen Sensor £30.00
Carpet sets 2 Styles; As OE £250.00 Improved £330.00
Trunk Carpet (Black or Grey) £20.00
Carpet Mats, Pair (Black or Grey) £48.00
Side Markers (Red or Amber) £25.00
LCA Bottom Ball joints £30.00
Engine bay Exhaust heat shield £25.00
S/Steel Polish £10.00
Explodaview Posters £9.95
As I mentioned above this is not a complete listing merely a ‘taster’ of what Dave has or can get. Please note that stock is subject to availability and plus Post and Packing where required.
It is also worth checking with other club officials or club members (via a forum posting) as to any parts that may be required as someone may have them in stock or be aware of a supplier.
Quote:LCA Bottom Ball joints £30.00
Is this what i need? Can i source up here, or purchase, in an extreme rush, from Dave? If so, could he post up here A.S.A.P?
Yes,
Call him he is usually very very helpful (number in mag)
Chris Williams Wrote:Yes,
Knew he was previously not well, so didn't fancy calling, since i don't know his personal circumstances right now. So ordered through Ed instead. Thanks for the heads up though.
Dave is ok, he just has to take things a bit easy. Because of this, he doenst want to drive far, so unfortunately wont be able to make it next week, but he will do shows local to him like Tatton Park.
He's always worth giving a ring if you're after summat, and he'll always have a tale to tell too :wink:
Hi just wanted to know do you still do the rear facia and is it complete many thanks
Quote:Hi just wanted to know do you still do the rear facia and is it complete many thanks
You would need to ring him to get an update on what he has, the list above is very old.
I had a rear fascia from him a few years ago, its just the fascia, no lights, etc, you'd need to
transfer stuff from your existing car onto it.
(06 Dec 2017, 10:15)Guinney1971 Wrote: I had a rear fascia from him a few years ago, its just the fascia, no lights, etc, you'd need to
Thanks. The car I’m thinking off buying Is missing all the back fascia  no lights nothing,no seats  the engine cover etc
