25 Mar 2009, 20:57
Hello everybody, I am after some technical assistance with the vacuum advance on 'UDW' or POS as I fondley call her. I have to own up, our very own club favourite, the very man who puts tourette syndrome sufferers to shame, Uncle Tony, together with Andy Carvosso changed the motor in the car for me to try and get me back into the enthusiam of having a Delorean, and all I had to do was finish it off. Which over the last couple of weeks I have been doing as I would like to take it to Eurotek, and use it as an Effigy and set fire to it!! No, as much as I have liked to have done that at times, i retract that statement because I don't mean it. Anyway, I have got the car running as per Volvo spec, she is running Volvo metering and air flow, and I have an auxillary air valve replacing the idle speed motor. As per the manual, she is ticking over at about 850/900 rpm and I have set the timing to 10 degrees. To do this the vacuum advance on the distributor has to be disconnected, but when I reconnect it the Rev's raise to about 1200, which is the vacuum advance pulling in. I then put a spark retard valve or a Vacuum delay valve in line from the inlet manifold to the dizzy, and all that does is the rev's increase at a slower rate rather than instantanously raising to about 1200. I know it's not right so i have disconnected the vac line to the dizzy. has anyone got any idea's as to what the problem might be??? I have already checked for vac leaks, and Tony reckons I should re-install the idle speed motor, but by doing that i am not resolving the problem. he also called me a c@#t as well, but thats a different story, so i am open to suggestions if any of you good people may have any idea's as to what the problem may be. Regards
Regards Jay Monk
VIN: # 3928
VIN: # 4989
VIN: # 3928
VIN: # 4989
