20 Apr 2008, 18:46
My D passed its test today , but had a pre-test niggles and a couple of failures.
The car started up first time on the button, drove ok, braked OK etc.
However, when checking the lights it popped a fuse on main beam.
The 20amp fuse was replaced and again it popped.
A lamp was removed and with a 15 amp fuse tried again, it worked.
The removed lamp worked on the bench.
The wiring was checked (no scotchlocks 8) ) and a multiplug was re-secured.
All reconnected with new 20 amp fuse.
Again it popped !!!!!!!
The 20 amp fuse was replaced with the 15 amp one earlier and all worked great !
Just goes to show not to trust the quality of fuses these days
The car failed on emissions (quickly sorted as fuel computer temporarily stopped working!) and failed on hand brake efficiency. My car is an auto so the hand brake is hardly used.
Luckily the garage I have used previously for MOT's was quiet sp they let me use a ramp and adjust the cable. The pads were OK.
After this I had to wait until the MOT braking rollers were free and after the formalities I got a PASS certificate
I am well chuffed seeing I have only done 500 miles since the last MOT. Most of that would have been EuroTech last year !
I also gave my Corsa Sport an oil & filter change, new spark plugs and fuel filter. This has cured the slight misfire just starting to occur first thing in the morning and the slight reluctance to start after the car was briefly run.
Just goes to show you need to keep on top of the servicing !
To top it off I have just quaffed my second beer and found out I don't have to be at work at 6am
All in all a great weekend.
