10 Mar 2008, 16:47
Hi folks
Well my problems seem to be continuing....
Took the car out today and onto the motorway, car went well in 3rd up to say about 55mph and 4000rpm, then it stopped accelerating and bogged down with a dramatic change in exhaust tone! it just would not rev any higher than 4000rpm, I changed into 4th and the car accelerated up to about 70mph but once it hit 4000rpm it stopped accelerating again and bogged down..... in 5th it just sits at about 70mph and wont go any higher.
I have new injectors, metering head, WUR, Fuel pump relay, fuel lines.... all of these have been fitted in the last 6 months. Car ran fine before I fitted the new metering head, fuel lines and new fuel pump relay (its the green one), I stuck in £25 of fresh petrol to see if that helped but it didnt make any difference.
I have never had this problem before and had thought it was a mixture problem but I have the car set to 2.5% and it drives PERFECTLY untill it gets to 4000rpm.
I doubt its the clutch as the revs dont increase while the speed stays the same and I have driven a car with a slipping clutch so it nots that, I expect its either the fuel pump or the fuel pump relay but I would love some advice before I start ripping things apart.
The car starts first turn of the key when cold and when hot.
P.S. The car will go higher than 4000rpm in 1st and 2nd, its just 3rd and 4th where I have a problem, although you can feel the car starting to bogg down in 2nd when you get to about 5000rpm
Please! Has anyone any idea!!!!!!?????
Alistair McCann
Northern Ireland
1981 Delorean #Vin Pilot 25
1989 Renault Alpine GTA Atmo.
Northern Ireland
