Fitting Hellas
#16
Yes. Some brighter than others, there should be no glow at all.
Assuming this is correct (I did check as best I could) then it should be like this:
Be good to get this checked one way or the other for everyone's benefit Big Grin
Looking at the back of the bulb, that's correct
Its 11.50 at night. but that's the drawing, isn't it? :?
You can pick up the feed from the marker lights in your bumper to supply the side lights, the connector is right next to the headlight units, behind the front grille. You need the RED/ORANGE and the RED/BLACK for the Right and Left sides respectively. There is also well known simple mod to convert the wing marker lights into side repeaters.
Headlights.
You have to switch all three pins around in the socket.
The BLUE wire with the RED stripe is for DIP (Low) Beam
The BLUE wire with the WHITE stripe is MAIN (High) Beam
That means you need to wire your socket like this:
