Threads: 350
wow, thanks guys!!
I'd been putting part nos into google and trying various websites to no avail :roll:
Not sure if I'll get time to mess about with car before the MOT on Wednesday morning, but will deffo have a go this weekend.
Nick, be interesting to see those graphs
Threads: 79
Heres a better list I found
It appears that the metering heads on DGS and flopsy are exactly the same but from different years.
DGS also has an 0438 120 065 air meter/venturi that I fitted at eurotec and nick tweaked up and its been running spot on since.
Yours should run ok then claire as both bits are off the 760... :?
Another Excellent find Dan !
Threads: 73
yep and i understand all of it, well not really :lol: TT
Threads: 812
Top stuff Dan, I did have a list of all the 260 & DeLorean part numbers. But have misplaced it :roll:
Threads: 56
I have the Volvo metering head, and Volvo venturi, the Volvo venturi is noticably bigger than the original DeLorean one but the car now runs pretty well.
I still need to set the emmissions on a exhaust analyser but I can't see how the OEM DeLorean venturi can ever work properly with the Volvo metering head,
anyone who was at Eurotech who heard my car running would have known that!
B28E (E=European)
B28F (F=Federal) i.e. USA spec emissions control
Some interesting comparison pics:
You can change over to the Volvo injection set-up but the B28E had a slightly higher compression than the B28F so unless you're going to go the whole
hog and change the pistons I don't think you'll get up to quite the same power levels as the Volvo.
Just my 2p.
James
Hi James
Nice Pics!
Can you confirm the overall diameter of each flap please
Threads: 73
I reckon the reason why the de one is smaller may be because the de runs a leaner mixture TT
Threads: 350
thanks for the pics and info everyone, will be a great help for us in tackling the car this weekend
Gonna fit the Volvo metering head that we've got and match it up to a Volvo Venturi, so that I've got a full Volvo set up - havent got a gas analyser, so will have to try and 'judge' the CO settings as best as possible - unless anyone local to us has a gas tester we can borrow for the weekend?
Threads: 73
have a word with the tester claire ask him if he dont mind adjusting it while your there, but like i said my mot place dont check it, so i would ask if its in their book TT
Threads: 350
Tourettes Tony Wrote:have a word with the tester claire ask him if he dont mind adjusting it while your there, but like i said my mot place dont check it, so i would ask if its in their book TT
The garage in Hulland Ward where we used to live did the emissions last year, and the garage in Derby that are MOT'ing it now have a copy of the old MOT so are just working off of that.
I think emissions checks on older cars is something of a grey area to be honest.
Threads: 350
ok guys, we think we've cracked it, without having to change the metering head (which wont fit the car as its got a port missing).
RichH came round and had a good look at the car and ferreted around, and found out that the car had been 'plumbed up' wrong.
Finger's x'd its all sorted, but I wont know until I take it for a run down to London tomorrow :wink:
Unfortunately, the mode switch is fubar, so my heater doesnt work, and we had to replace a headlamp fuse that had melted..... :roll: Oh, and the replacement angle drive is also a pile of scrap (yay, another failed DMCH angle drive.... :roll: )
Threads: 812
Hi Claire,
Is the missing port for the frequency valve? If so that is correct for Volvo spec stuff as it's not used.
Threads: 350
cant remember mate, I was busy in the kitchen cooking and Phill and Rich were out in the rain
checking the new metering head against the one on the car and the pipework.
Phill will be here in a bit, I'll ask him which bit is missing on the new metering head.
