Cold start and running issues
Not sure if this is in the correct area
Looking for some advice.
Car was running great
Now very poor cold start, when eventually running at temp misfire at low RPMs and cuts out when stop as idle drops too low
Any ideas ?
I have checked cold start injector that’s working
Next plugs ?? Leads ??? Dizzy cap ???
Anyone had this before. ?
Any advice would be appreciated
Simon
Difficult one really, could be anything. I would suggest jumping your fuel pump relay to try and eliminate fuel related issues, then your down to basic checks as you mentioned. Generally you need to (as I'm sure your aware) eliminate one or the other fuel or spark and work from there.
Check for split or loose vacuum lines, especially to the Control pressure regulator (Warm up regulator)
