06 Jan 2014, 05:15
It's not just Spratty I''ve heard it from either Chris.
Rich H confirmed this yet unless the check valve is somewhere between the top of the pump and the flexi line in the way of a brass fitting either side of the banjo bolt, then I have no idea where else it could be located.
It's odd though because only one pump is listed in any parts catalog and the only check valves listed relate to air con and auto transmission. Maybe I'm looking for something that doesn't exist!
If it turns out it is integrated then I might invest in a new pump.
The more info I can gather on this though, the better so thanks Chris!!
Ben
Ben
