Threads: 79
under the front of my car today.
just a quick question:
there's physical movement inside the pass side gator i can physically move the tie rod up and down (that's from floor to ceiling) by approx 10-20mm. can't on the driver's side.
should this happen? The steering's loose at the moment , but that's due to a missing column bushing. there's no slop in either tie rod ends and the main rack is solid. it's just inside the gator where there's movement. What I'm basically saying is there's play.
any ideas?
- Dave Smith
VIN: #00944 DOC: #535
VIN: #03193
Threads: 73
you need a new rack, my one was the same you have a missing bush and i have heard of another being the same side as well. TT
Threads: 15
are ya track rod end nuts done up if so then yep new rack or and new track rod ends
REG DMJ 287X
CLUB MEM. NO. 554
VIN NO. 05583
HEY LAZER LIPS!!!....
Threads: 79
tie rod ends are fine from what i can see - minus the boot and some grease.
ho hum
I'll get those driveshaft people to take a look at it.
pain in the arse to remove?
cheers lads.
- Dave Smith
VIN: #03193
Threads: 73
quite easy to get out just cant remember what way left or right
TT
one thing i will say is dont cut corners and with things like steering they must be right, you only have one life. lecture over :wink:
The pass side rack bush fails and it's a rebuild to repair properly. It's a Lotus part or John Hervey is now replacing the original plastic ones with brass ones on his rebuilds due to high failure rate. Not sure if he'd be happy to supply the part seperately.
The rack comes out to the driver's side. Silicone spray grease or fairy liquid is really useful for removing and replacing the rubber mounts.
Threads: 79
got the rack out.
actually pretty easy
- Dave Smith
VIN: #03193
Threads: 73
yeah just wait till you got to put it back :wink: TT
Threads: 814
Tourettes Tony Wrote:yeah just wait till you got to put it back :wink: TT
mmm, then get the rubber mounting bushings on the rack and the brackets over them :x
Chris Williams Wrote:mmm, then get the rubber mounting bushings on the rack and the brackets over them :x
... without getting crap in your eyes...!
DO NOT forget the critical plate that goes under the square bracket - the flange on the rack slots into the two little tongues and stops the rack playing from side to side. I've had at least three cars come through my hands where that plate was missing, and it makes for awful steering.
