Threads: 73
I have decided to tackle my door strutt mountings, the one on the drivers side was the worse, and i have just discovered that they have already been repaired, now with my car showing 24k when i brought it in and the lambda light coming on at 29,975 mls i assume its right. Has any one not repaired theirs TT
Im assuming you mean the ball joint attached to the fibreglass?
Ive not touched mine. as yet ......
Threads: 350
TT - whats the prob?
I'll get Phill to speak to you tomorrow, as the pivot bolt on Sorbet snapped last year - luckilly when the door came down, the strut went vertically downwards, rather then to the side and damaging the stainless.
I'll also ask Phill to do a tech article on how he repaired his complete with photos.
cheers,
Threads: 43
Claire Usher Wrote:I'll also ask Phill to do a tech article on how he repaired his complete with photos.
STOP PRESS! Funnily enough Phill's article is appearing in the forthcoming issue of
DeLorean News!
Threads: 73
it turns out the actual bracket is bent, iv got the t-piece off and rear quarter panel and i have a cunning plan to extend the bracket further in behind the fibre glass, the main problem is the strutts are to power full and i will be getting propper ones from the states to avoide this happening again, next job discs and turbo rebuild and volvo metring head and venturi TT
Threads: 350
Phil Peters Wrote:Claire Usher Wrote:I'll also ask Phill to do a tech article on how he repaired his complete with photos.
STOP PRESS! Funnily enough Phill's article is appearing in the forthcoming issue of DeLorean News!
ah cool thats ok then
I might do one on my n/s handbrake caliper. Apparantly last year, it failed the MOT when the car was down in Kent because it wouldnt adjust - I'm not surprised it wouldnt adjust, the caliper was broken! Anyway, thats another story, and Phill repaired my caliper for me and the handbrake works fine now (for a DeLorean)
Threads: 73
bozzzydmc Wrote:Its good your fibreglass is ok matey.
http://www.delorean-parts.com/Merchant2 ... gory_Code=
I was recomended these, and to everyone I have mentioned these to and have bought these since have all had a good experience with them.
weather its hot or cold out they seem to perform the same.
ie no 'bounce' at the top in hot weather.
thanks mike i will order a set, the ones i had fitted were far too stiff and put too much stress on the body mounts, kelvin has a set of pj gradys on his car and they are so easy to shut, and they open fully TT
Threads: 18
Claire Usher Wrote:it failed the MOT when the car was down in Kent
East Sussex my dear :wink:
Threads: 350
Daniel Shane Wrote:Claire Usher Wrote:it failed the MOT when the car was down in Kent
oops, sorry dude - its all 'daan saaf' to me :lol:
