Anyone here a qualified electrician? advice please :(
got this back from electrolux:
Thank you for your email
I can confirm that this appliance does work on a 13amp fuse as per the brochure.
The paragraph in the instruction book is under review with the factory as it is incorrect.
Please accept my apologies for any inconvenience this may cause
Kindest regards
Electrolux Consumer Care Team
my original message:
Hello
Unfortunately is appears you've given me duff advice. I'm in receipt of the below oven and it doesn't come with a flex or 13amp plug.
The manual which comes with the oven says:
"Connection via: cooker control circuit
min cable/flex size: 2,5mm2
cable flex: PVC/PVC twin and earth
fuse: min 15A / max 20A
It is necessary that you install a double pole switch between the oven and the electricity supply (mains), with a minimum of 3mm between the switch contacts and of a type suitable for the required load in compliance for the current regulations"
This is contrary to the advice you've given me.
I'm now stuck with a potential bill from an electrician to install a cooker control circuit and the cooker.
Dave.
- Dave Smith
VIN: #00944 DOC: #535
VIN: #03193
