Ignition timing?
Would someone be good enough to confirm the ignition timing for me please? from memory is it 12% BTDC with ignition advance detached? or am I completly wrong??
as far as im aware your 1degree out it should be 13 but what do i know :lol: do i sound like someone else :oops: TT
That is correct Tony
(13 Degrees + or - 2 degrees @775 rpm plus or minus 50 ) Workshop manual
If you have the Volvo dizzy and metering head then you should be running at 10 degrees BTDC
Thanks, I have the volvo dizzy on but not the metering head as yet, so will set at 10%
Thanks for the help
Talking about the volvo gear, if anyone has it i will buy it Cheers TT
If you have the volvo distributor on, leave the advance solenoid on too.
Disconnect the oxygen sensor electrically and set the fuel mixture to 2 to 2.5% co.
Once you have the oem B28E fuel distributor, matching CPR and metering head/flap (v important for the correct fuel curve) then bypass the thermo switch completely.
DISTRIBUTOR SOLENOID--------VAC ADVANCE ON SOLENOID
T---INLET MANIFOLD
CPR
I have a second hand volvo B28E dizzy if you want it. Works fine I got hold of a recondiitioned one for the engine I built. £15 and its yours will even through in a new rotor arm and cap!
NickT Wrote:If you have the volvo distributor on, leave the advance solenoid on too.
T---INLET MANIFOLD
CPR
Sorry Nick dont quiet follow this perhaps you would be good enough to show me next weekend? (or explain in more simple terms Shock )
OK I'll show you at Eurotec.
What I posted was an attempt to show you a modified vacuum route using ascii characters.
IE the vacuum piping goes from the inlet manifol to a T piece.
From this T piece (1) to the Distributor Solenoid.
From the Distributor Solenoid to the Vaccuum advance on the distributor.
From the T piece (1) the other side goes to the Volvo CPR.
Good luck.
Chris & Suzie William Wrote:I have a second hand volvo B28E dizzy if you want it. Works fine I got hold of a recondiitioned one for the engine I built. £15 and its yours will even through in a new rotor arm and cap!
Done, bring it with you chris if you can, cheers tony
Will do mate.
