17 Aug 2009, 20:15
1981 DeLorean DMC 12 Stainless Steel Coupe
Black interior, Automatic, 6cyl, Bosch K-Jetronic
34,617 original miles
June 1981 build
VIN # 01674
CarFax available
This DeLorean coupe is in excellent condition, inside and out, the engine has recently undergone a top- end overhaul, including heads, valve guides, adjustments, gaskets, plus new plug wires, distributer cap, rotor, plugs, all new vacuum lines. Air Conditioning has been converted from R-12 to R-134a and blows cold. The interior is in very good condition, seats are soft and supple, no cracking.
Some small issues:
The dash has a small crack near the glove compartment, and another near the speaker grille on the same side. There is a small hole in the material of the passenger side knee pad, wear on the drivers side trim behind the door (where you brush it entering and exiting the car). The binnacle is in perfect condition.
Slightly larger issues:
There is a crack in the windshield, probably repairable and I will try to have it repaired as soon as I can.
The Transmission Computer Governor needs to be rebuilt, the car still drives fine, but you must manually shift from 1st to 2nd then to Drive. Replacements are available from multiple DeLorean vendors.
Aftermarket stereo (Kenwood AM/FM/CD/MP3 player) I am the third owner of this wonderful car, and have the original window sticker, and maintenance receipts from the previous owners, as well as my own. Owners manual, DeLorean Shop Manuals (hardcopy and in .pdf form) and other extras.
This is a fairly well sorted DeLorean and would make a nice addition to a European garage. It is turn-key for fun, and still leaves some tinkering to be done.
This car is a daily driver, and does not have any of the usual issues found in a DeLorean which has sat in storage.
I can send extensive photos on the request of a SERIOUS inquirer, tell me what you would like to see, and I will take fresh photos for you.
SERIOUS INQUIRIES ONLY PLEASE!
$20,000 (nego.)
email johnzd81@yahoo.com
June 1981 build
VIN # 01674
CarFax available
Some small issues:
$20,000 (nego.)
