swapping over to volvo offers please
hi all, im in the process of changing over to volvo gear so venturi throttle housing metering head idle motor and idle ecu are up for offers, i also have a ally header tank which has always had a slight hiss but could be sorted if you had the time to get it seated properly, or even a change of cap might work, pm me if interested this offer is to club members only
cheers my friends TT
i also have a cold start valve, ignition module coil ballast resistor as well as the inlet bendy thing, distributor, and yes i did rob it blind as you can tell TT
