SP10460 - SCREW M6X12 - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: GENERAL DELOREAN DISCUSSION (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=2) +--- Forum: DeLorean Cars or Parts For Sale or Wanted (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=26) +--- Thread: SP10460 - SCREW M6X12 (/showthread.php?tid=807) |
SP10460 - SCREW M6X12 - Barson - 29 Jul 2007 Hello I'm after four of these. They're the ones that attach the lower door trim to the door. see pic. anyboy got afew of these knocking about? They're not other M6 screws that attach the trim to the door (those ones are bigger - code SP10455) . cheers Barzo - Tourettes Tony - 30 Jul 2007 are they m7? - Barson - 30 Jul 2007 m6
- Tourettes Tony - 30 Jul 2007 best to buy some and cut them down, i done that with manifold studs TT - Barson - 30 Jul 2007 I was thinking that ![]() thanks. - Tourettes Tony - 30 Jul 2007 a little tip though, put a nut on before you cut them then it re-threads itself, i know you know but il say it all the same :wink: TT - Barson - 30 Jul 2007 ![]() When I cut down threads I usually use my little black & Decker wizard to clean up the ends. 9 out of 10 times it works and just screws on (neat ), but I shall try your suggestion also.:wink: - bozzzydmc - 30 Jul 2007 Have you tried B and Q? im sure i have had some from there before
- Tourettes Tony - 30 Jul 2007 and just for good measure, screwfix direct for stainless steel fixings if you cant be bothered to go out :lol: TT |
