Quick Question - your opinions. - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 2 - Emission / Fuel Systems (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Quick Question - your opinions. (/showthread.php?tid=75) |
Quick Question - your opinions. - Barson - 27 Sep 2006 Hello. When I was looking over the engine compartment, shortly after I got the car, a mechanic friend and I noticed this: ![]() The two should be joined by a small tube. Can anybody tell me what difference not having the tube fitted will make to the running of the car? It's only a little thing, but i thought I'd ask around first before I shell out for a 2" piece of tubing :p cheers m' dears. :lol: Barzo - bozzzydmc - 27 Sep 2006 ![]() must have dropped off ...hell of a vacuum leak that ![]() Check all of your other vac pipes for correct routing and condition whilst you are there matey. - ChrisS - 27 Sep 2006 You will have poor acceleration while the engine warms up..not to mention the vacuum leak! Once the engine is up to running temp it will not make any difference as the vacuum is only supplied to that pipe when the engine is cold. - Barson - 27 Sep 2006 cheers lads. I checked out the other tubes and they all seem to be in place and in relatively good condition. I'll install a new tube in there and see what happens. ta! Barzo - stunned_monkey - 28 Sep 2006 As Dan said, it'll only be affected when cold. - bozzzydmc - 28 Sep 2006 stunned_monkey Wrote:As Dan said, it'll only be affected when cold. That will be Chris, Dan's alter ego then
- ChrisS - 28 Sep 2006 bozzzydmc Wrote:That will be Chris, Dan's alter ego then Damn the cat is out of the bag, have you noticed Chris is hardly ever in the same place at the same time as me..and when he is its all smoke and mirrors :wink: Dan..i mean Chris ( or Dan with a syrup )
- Daniel Shane - 28 Sep 2006 Change your avatar then chris ![]() And syrup, you cheeky sod!!! - stunned_monkey - 30 Sep 2006 Well the car in my avatar ain't mine either but at least it a) was and b) is a DeLorean! - ChrisS - 30 Sep 2006 stunned_monkey Wrote:Well the car in my avatar ain't mine either but at least it a) was and b) is a DeLorean! You need stronger contact lenses mate, look a bit closer and you can see my car ... not my fault that Dan decided to park infront of it when I took the pic
