Short running - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 1 - Engine (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=13) +--- Thread: Short running (/showthread.php?tid=69) |
Short running - Chris Hawes - 26 Sep 2006 If a DeLorean is started from cold, reversed out of the garage and then immediately driven back in and the engine shut off on nearly a daily basis would this do the car any harm? This is purely for moving the car out of the way to get at other stuff in the garage... - Tourettes Tony - 26 Sep 2006 Well i wouldnt do it chris, you will get a lot of condensation in the oil, which probably wont hurt , but imo not good cheers Tony TT - Birksie - 26 Sep 2006 Yep. Not only that, cold oil doesnt do its job very well. Plus, not moving very far doesnt get the system lubed very much. IMHO. I wouldnt worry too much, unless you're doing this every day! - stunned_monkey - 27 Sep 2006 For the first 3 minutes, the car is running rich. Keep shutting it off before it's warm and you'll soak the oil in fuel. |
