Seat Removal - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 8 - Frame / Body / Interior (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Seat Removal (/showthread.php?tid=68) |
Seat Removal - Barson - 25 Sep 2006 Hello. 8) I need your help. To cut a long story short, I need to re-attach the handbrake cable nipples to the handbrake handle mechanism. To do this I need to remove my driver's side seat. (LHD) to get proper access to the handbrake. Can anybody give us some quick advice on the best way to do this? I've located, underneath the rear of the seat, two square nuts that i believe are holding the seat to the rails (is this right?). Are there any other nuts holding the seat down? and is there anything else i need to look at first before I do this? :? :oops: :lol: I'm being quite cheap and cheaky in asking this, because im in the midst of purchasing a set of manuals, which would probably tell me all I need to know... thanks! Barson. Re: Seat Removal - bozzzydmc - 25 Sep 2006 Barson Wrote:Hello. 8) The seat is held down via its runners to the floor through the black fibre glass if you look underneath the car you will see 4 big nuts and washers holding it down ...simple when you know eh
- Barson - 25 Sep 2006 BOZZZY! all done. cheers mate. I now have handbrake working on both rear wheels! :lol: Although I did screw up by over-tightening the one of the under side bolts on the handbrake bracket, sheering off the screw... bummer. :roll: cheers Barson
