Warm Up Regulator - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 2 - Emission / Fuel Systems (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Warm Up Regulator (/showthread.php?tid=650) |
- bozzzydmc - 29 May 2007 Hi Dean I know this is all starting to sound like a 'stuck record' , but as NickT has pointed out, has your mechanic done a proper fuel pressure test ?, this will confirm if the part is faulty or not. No point of spending hard earned cash on parts you dont need bud . In no way as detailed as NickT s 'How to' in the back of the last mag but of some use all the same :- http://mysite.verizon.net/vze7u0gn/id4.html BTW All:- There will be a fuel pressure test kit available for use at Eurotec. Along with a demonstration session on this. - bozzzydmc - 29 May 2007 Hi Dean With respect to the guys you have taken your car too , they really dont know what they are doing. All its doing is giving you frustration and costing time and money at the moment. The tests are very simple and instantly tell you 'whats up' Can you see if there is anyone around you who knows the K-Jet system and can rig up a fuel pressure guage to your car to do these tests? If i was a bit nearer i would have gladly taken a look. - Guinney1971 - 29 May 2007 when are you back from the US Dean? Mebbe someone could swing by yours on the way back from Eurotech if your back? Your up near Peterborough if I remember? - Chris Williams - 06 Jun 2007 You could always drive down to mine and swap my good one for yours. when cold, check and then swap them back over. Chris |
