33 DMC Parts (15 new / 18 used) some are rare items, auctions end Sat 6th March 21 - Printable Version
+--- Thread: 33 DMC Parts (15 new / 18 used) some are rare items, auctions end Sat 6th March 21 (/showthread.php?tid=6124)
33 DMC Parts (15 new / 18 used) some are rare items, auctions end Sat 6th March 21 - Chris Hawes - 24 Feb 2021
I’m having a clear out of new/used parts.  Some of these parts (new and unused) are no longer available from any of the vendors.  All of the items finish in the evening of Saturday 6th March GMT.  Shipping is free to all UK buyers.  International buyers are welcome, but please contact me before bidding so that you’ll know what your shipping rate will be.
New
111388            Hood Edge Strip 44" –Side
https://www.ebay.co.uk/itm/164722503367
111389            Hood Edge Strip 59" – Top – SOLD
105542            Brake Servo
https://www.ebay.co.uk/itm/164722504213
100289            Stainless Brake Servo Booster Mounting Bracket
https://www.ebay.co.uk/itm/164722505098
108534            The DeLorean Go Silicone Rubber Door RH Fixed Glass Perimeter Seal
https://www.ebay.co.uk/itm/164722505529
108533            The DeLorean Go Silicone Rubber Door LH Fixed Glass Perimeter Seal
https://www.ebay.co.uk/itm/164722505972
108205            accelerator pedal cover only
https://www.ebay.co.uk/itm/164722506751
106130            angle drive
https://www.ebay.co.uk/itm/164722507541
108737            hood seal
https://www.ebay.co.uk/itm/164722508116
SP10497         INNER DOOR SEAL EDGE CLIP
https://www.ebay.co.uk/itm/164722509032
106781            No Drip Tape
https://www.ebay.co.uk/itm/164722509919
100701            LH OEM NEW belt and OEM NEW receptacle inc OEM NEW plastic cover
https://www.ebay.co.uk/itm/164722514206
100702            RH OEM NEW belt and OEM NEW receptacle inc OEM NEW plastic cover
https://www.ebay.co.uk/itm/164722514986
105085            OEM EXTERIOR MIRROR ADJUSTMENT SWITCH
https://www.ebay.co.uk/itm/164722515536
108209G         PJ Grady Gas Strut - Louvre (single)
https://www.ebay.co.uk/itm/164722515929
105257            Rubber boot for lower ball joint/tie rod end/track rod – SOLD
Evaporator Protector Mesh
https://www.ebay.co.uk/itm/164722517566
Used -    All of the below are original OEM 1981 parts from an Oct 1981 build
100181            11 used OEM wheel nuts
https://www.ebay.co.uk/itm/164722518118
100701            LH OEM belt used and NEW OEM receptacle not inc plastic cover
https://www.ebay.co.uk/itm/164722518454
100702            RH OEM belt used and NEW OEM receptacle not inc plastic cover
https://www.ebay.co.uk/itm/164722518745
110416            Mirror glass – SOLD
110520            Fuse Box Cover – SOLD
101064O         Original (Black) RPM relay – SOLD
106720            RH REAR SPEAKER BRACKET
https://www.ebay.co.uk/itm/164722519034
106721            LH REAR SPEAKER BRACKET
https://www.ebay.co.uk/itm/164722519457
108748            OEM grooved ash tray
https://www.ebay.co.uk/itm/164722520460
108288            OEM Cigar Lighter complete with illuminated ring
https://www.ebay.co.uk/itm/164722521096
110523            Console Cover grey
https://www.ebay.co.uk/itm/164722521937
110521            Console Tray grey
https://www.ebay.co.uk/itm/164722522716
105104            Speedometer Drive Dust Shield – SOLD
101440            STORAGE (CUBBY BOX) LOCK – SOLD
105610            DeLorean DMC-12 OEM Pair Of Dummy Switches
https://www.ebay.co.uk/itm/164722523546
https://www.ebay.co.uk/itm/164722524029
101488            Tail Light Boards with Incandescent Bulb Kit – SOLD
100169O         OEM drive shaft
https://www.ebay.co.uk/itm/164722524911
118702            Rear wheel (hub area needs repair)
https://www.ebay.co.uk/itm/164722525842
101044            OEM Starter Motor – SOLD
100462            Clutch Master Cylinder DMC
https://www.ebay.co.uk/itm/164722526200
110085            OEM Fuel Pump Bosch
https://www.ebay.co.uk/itm/164722527057
108683            Fuel Tank Baffle Outer Retainer Spring
https://www.ebay.co.uk/itm/164722533865
100817            Lamp Delay Unit
https://www.ebay.co.uk/itm/164722534469
7701499465     Renault Alternator
https://www.ebay.co.uk/itm/164722546718
Back To The Future related items
AOSHIMA Amerang motorised Back To The Future Part 3 DeLorean – Built
https://www.ebay.co.uk/itm/164722577123
Back To The Future – SMITHS – Board Game 1985
https://www.ebay.co.uk/itm/164722651429
Aoshima Back To The Future Part 1 DeLorean 1:24 Scale (incomplete)
https://www.ebay.co.uk/itm/164722594983
Aoshima Back To The Future Part 2 DeLorean 1:24 Scale
https://www.ebay.co.uk/itm/164722596116
Aoshima Back To The Future Part 3 DeLorean 1:24 Scale
https://www.ebay.co.uk/itm/164722597217
Halcyon Back To The Future Part 2 DeLorean 1:24 Scale
https://www.ebay.co.uk/itm/164722598122
Halcyon Back To The Future Part 3 DeLorean 1:24 Scale
https://www.ebay.co.uk/itm/164722598592
If you have any queries, please message me via the listing on eBay.
Best wishes
