Metering Heads and Distributors - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: Business Links (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: Parts Suppliers (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=37) +--- Thread: Metering Heads and Distributors (/showthread.php?tid=594) |
Metering Heads and Distributors - bozzzydmc - 07 May 2007 Thanks goes to Dan Shane for the info:- I used KMI their number is 020 73857138 to refurbish the Metering Heads. For the Stage 2 engines we used the Volvo 260 Head. KMI will supply Capri metering heads speced to the Volvo flow rate for the cost of the refurb, so you dont need to find a metering head. The Injectors were not changed from standard ones, however the spray pattern was checked. There was a problem however and that was the Hydrocarbons. It was tricky to get the engine through an MOT but not impossible. Also with the high lift cams the Tappet gap is Increased. Dan _________________ Dan Shane DOC #423 97' Lotus Esprit GT3 99' Lotus Elise 99' BMW M5 E39 92' VW Golf GTI |
