Tap Tap Tap. - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 1 - Engine (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=13) +--- Thread: Tap Tap Tap. (/showthread.php?tid=579) |
Tap Tap Tap. - Barson - 05 May 2007 Hello My engine seems to have developed (or I hadn't noticed before) a tap from the passenger side valve cover. I've attached an MP3 of the sound if it's easy to diagnose. Does it sound like tappets? The engine's doing 900rpm at that point and hunting slightly. Initially when I first heard it I described it as a knock, which now appears to be mistaken. Another thing that maybe related is that I get a backfire into the intake when I rev. thanks for your help. Dave. - bozzzydmc - 05 May 2007 The noise you describe could be an exhaust manifoid gasket leak, they do sound similar. Try and investigate this .. but be wary that from cold these mnaifolds get hot and quick ( if you are feeling around them for signs of this ) cant hear your mp3 file thou. Have your gaskets been replaced in your knowledge? Back fire sounds like a fuel mixture / timing issue - Barson - 05 May 2007 thank you mike. I will investigate this. the manifolds have not been replaced to my knowledge. The mp3 works alright for me (takes afew seconds to D/L, though). Does it D/L and you hear silence or does it not D/L at all? thanks Dave. - NickT - 05 May 2007 remove the cam cover and have a look at the valve train noting the valve clearances (tappets) NickT. - Rich H - 05 May 2007 Quote:Does it sound like tappets? Sure does. Oddly enough it always seems to be the passenger side... - bozzzydmc - 05 May 2007 now i have heard your mp3 ...yes that sounds like its tappet related to me
- Tourettes Tony - 05 May 2007 RichH Wrote:Quote:Does it sound like tappets? Thats because it takes so long to do them the owner says sod this il let someone else do it :lol: :lol: TT - Daniel Shane - 06 May 2007 Agree, it's always the passenger side that gets noisy. One of the 'Features' of the PRV Dan - Barson - 06 May 2007 I've failed in my attempts to silence the tapping. Although, I have reduced it to a point where you have to tune in to the sound (over all the other sounds of the engine) to hear it. I'll have another go later to see if i can improve on my attempt. suppose we should be thankful that it's always on the passenger side and not on the other side. thanks for your help. Barzo. |
