Fuel gauge is pointing down no matter what - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 3 - Electrical (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=15) +--- Thread: Fuel gauge is pointing down no matter what (/showthread.php?tid=5782) |
Fuel gauge is pointing down no matter what - Chris Hawes - 26 Mar 2018 Another new recent problem, my fuel gauge is pointing down no matter what. So far I've done the following:- I've used the multi-meter to verify that the signal from the green/black wire (for the gauge needle) beeps at the plug for the sender as it does on corresponding pin (A4) on the big white connector behind the binnacle. I then kept the multi-meter on the same sender end of the harness and tested each other pin of the binnacle connector expecting to hear another beep from another wire to indicate a short, but there were no other beeps. I then performed the same test for the light green and orange wire (for the sender light) in the same way to the above, only to find the same outcome. I'm pleased that there appears to be no short but stumped as to why my gauge is all of a sudden pointing south. The other gauges are all still running perfectly. Any input or suggestions would be most welcome. Thanks in advance Chris RE: Fuel gauge is pointing down no matter what - Chris P - 27 Mar 2018 I don't understand the technicalities at all Chris.....but when mine developed a fault, about a year ago, we removed the sender and cleaned it up a bit and it been fine since. Not much of a job to try it. RE: Fuel gauge is pointing down no matter what - Chris Williams - 27 Mar 2018 Would there be a chance that whilst fitting a new pump something has been re-fitted so that its keeping the float pressed down? or been damaged during pump work? Chris RE: Fuel gauge is pointing down no matter what - TristanC - 27 Mar 2018 What I would do (tell me if I’m out of line here because I’m not yet an owner) is to take the float mechanism out of the tank and try manually moving the float to see if it affects the gauge..... 2 man job of course. (And gently does it) And I guess if the fuel pump is part and parcel of this, then my idea sucks, unless you can disconnect the pump. Same thinking as Chris in terms of something jamming the float down, at least if this works you can be sure the float mech is operational. RE: Fuel gauge is pointing down no matter what - Chris Hawes - 31 Mar 2018 Through the testing (as per the video I've just uploaded via the thumbnail above) I was able to confirm the issue wasn't the wiring or sender.... I hope this helps anyone else in the same scenario! RE: Fuel gauge is pointing down no matter what - Chris P - 31 Mar 2018 Excellent Video Chris....even I could understand it! ![]() RE: Fuel gauge is pointing down no matter what - Chris Williams - 31 Mar 2018 Top stuff, but why does your tacho needle go all the way around? Chris RE: Fuel gauge is pointing down no matter what - TristanC - 31 Mar 2018 Great video Chris, thanks for sharing. Tris RE: Fuel gauge is pointing down no matter what - Chris Hawes - 01 Apr 2018 Great spot Chris, I'd noticed that too since In summary, some gauges 'remember' their last readings when the ignition is off and it looks like I've added another quirk into the mix ![]() RE: Fuel gauge is pointing down no matter what - Chris Williams - 01 Apr 2018 Quote: From memory, I think any DeLorean 'remembers' the last tacho reading from when the ignition was last on. When you turn on the ignition circuit, the tacho then resets back to zero which again I think is the same from stock.Cant argue with that, it was how yours jumped all the way around to the top that was a surprise, I had never seen that before. Must be all that extra power your packing and the cars getting itself ready for it. ;-) Looks a superb conversion BTW Chris |
