Clutch issue - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 4 - Transmission - Manual & Automatic (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=16) +--- Thread: Clutch issue (/showthread.php?tid=5781) |
Clutch issue - cummil2 - 24 Mar 2018 I parked the car up last year , today after staring it and running for an hour I went to drive it , Clutch works perfect and allows to select gears , But on releasing the clutch the does not move what’s so ever , any help appreciated , RE: Clutch issue - Chris Williams - 24 Mar 2018 Sounds like you have the same issue Priesh had. You need to check the hydraulics: Is there fluid in the reservoir? check for any fluid leak from the Master cylinder in the drivers footwell (most likely) check for fluid leaks around the clutch master cylinder behind the front wheel. Chris RE: Clutch issue - priesh - 25 Mar 2018 Were you selecting gears when the car was running or when it was off? If you are able to depress the clutch and select a gear when it is idling then you'll know if it's hydraulics or not. What does the pedal feel like? |
