 Distributor cap orientation? - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 3 - Electrical (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=15) +--- Thread: Distributor cap orientation? (/showthread.php?tid=5763)  |
Distributor cap orientation? - priesh - 26 Feb 2018 Hi all - I am going to swap out my cap with a new one soon, and just had a question on orientation. I know there is a notch in the cap for alignment purposes (i took a pic and highlighted the notch - see below), and I assume there is a cutout on the distributor body to accomodate it (haven't had time to look properly) However, if this is the case, how do people sometimes manage to put it on 180° rotated? Surely it shouldn't fit? [attachment=292] RE: Distributor cap orientation? - priesh - 26 Feb 2018 I looked at the distributor itself earlier - thankfully the notch is quite obvious. Still not sure how people fit it on incorrectly as I wouldn't have thought the clips would then reach. I took a pic in case anyone is interested - the dust cove ralso has a tab that fits into the notch: [attachment=293] RE: Distributor cap orientation? - Chris Williams - 26 Feb 2018 It happens, I guess it's usually when trying to do it without removing the fuel metering head as you have done. IIRC it does notch in 180degrees out (or feels like that) Chris RE: Distributor cap orientation? - priesh - 27 Feb 2018 Ah OK - well I'd better not screw this up considering I can actually see it lol  |
