Car won't start - suggestions? - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 1 - Engine (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=13) +--- Thread: Car won't start - suggestions? (/showthread.php?tid=5740) Pages:
1
2
RE: Car won't start - suggestions? - Future - 13 Feb 2018 (13 Feb 2018, 10:52)priesh Wrote: Turns out it is likely the battery as I tried starting with a battery booster and it started without issue. I did still have the thermotime disconnected so once I have a new battery I'll try it with that reconnected. Do you have a battery switch ? Some of the diodes in the car let small currents through. Not sufficiently shutting the door might also leave the lights on in the car... draining the battery. RE: Car won't start - suggestions? - Chris P - 13 Feb 2018 That my first thought a month ago..... RE: Car won't start - suggestions? - Future - 13 Feb 2018 (09 Jan 2018, 16:44)priesh Wrote: Hi all, I guess he did. Better try that new battery. Worked fine by me. RE: Car won't start - suggestions? - priesh - 16 Feb 2018 I think I was holding off as I was told the battery was not old, but having changed it today I think it has done the job. I got a Varta E38 096 battery - fits in the comparment but doesn't sit completely in the well - assume that's ok? RE: Car won't start - suggestions? - Chris P - 16 Feb 2018 I ALWAYS use a battery isolating switch, even if I leave it on trickle charge. Deloreans are worse than most classic cars for draining away amps. |
