Fuel pressure testing - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 2 - Emission / Fuel Systems (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Fuel pressure testing (/showthread.php?tid=570) |
Fuel pressure testing - Sirolf - 02 May 2007 Hi guys On another D i'm working has the problem to accelerate very badly. Feels like a incorrect fuel pressure, no vacuumleak cause the idle is a steady 800. I hooked a gauge in the fuel line going to the CPR. What pressure exist here? I'm reading nothing... Frowner Think the Fuel Distributor is shot.. Thanks... Greets Floris - NickT - 03 May 2007 Are you a paid member of the "De Lorean Owners CLub UK" ? I've written a full fuel injection pressure test procedure for the club magazine. Ask Mike Bosworth (bozzzy) for a back copy when you join. Cold CPR Pressure - depends on temp of the CPR Warm CPR Pressure - 3.4 to 4 bar roughly. Check the routing of the vacuum pipes first to/ from the thermo-vac switch as chances are the piping to the CPR and the Spark Distributor will be swapped over. NickT. - Sirolf - 04 May 2007 No, i'm not a paid member.. I checked pressure yesterday..more than enough. Adjusted air/fuel mixture to its best.. But still no power enough when driving, injectors though don't show a nice enough spray pattern..does this influence performance a lot? - NickT - 05 May 2007 Have you checked the vacuum pipe routing? There should be a diagram on the underside of the engine cover. Poor injector spray pattern can account for a sluggish response but 9 times out of 10 a clean can restore them. NickT. - Sirolf - 06 May 2007 Rebuilt the VOD from ground up yesterday using new vacuum hoses and o-rings. Set emissions to its best... Somewhat better. Stiil spray pattern is aweful, so cleaning them is next to see if it helps, otherwise replacing them. - NickT - 06 May 2007 I have a bosch k-jetronic injector spray/ pressure tester. I could test/ clean them for you but you will have to pay return postage. I think new ones are £35 each. Standard B28E fuel injectors. Bosch (014) 0437 502 022 Book specs: Break pressure >3.5bar Rest pressure min 3.3 bar NickT |
