Removing Engine/Gearbox (and installing) Tips/advise/help!!! - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 1 - Engine (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=13) +--- Thread: Removing Engine/Gearbox (and installing) Tips/advise/help!!! (/showthread.php?tid=569) |
Removing Engine/Gearbox (and installing) Tips/advise/help!!! - Chris Williams - 02 May 2007 Hi, Now I have obtained a better higher power engine I plan on installing it (duh) And was looking for an idiots guide to removing the engine gearbox unit/reinstalling it. As in best sequence/possible pit falls/ etc etc. Ie; how does the clutch slave come out? Is there a procedure for this written anywhere that I can refer to? (the whole removal procedure) Any one fancy helping out for a few beers/curry. What parts should I have in, Clearly have got all the gaskets that I think I need, new exaust manifold studs are in the new engine, Anything else that springs to mind??? Anyway sorry for the long question but I dont want to get it out and then be stuck awaiting parts :oops: Cheers Chris - NickT - 02 May 2007 Oooh sounds like an interesting project. What engine have you got planned? Pity I live so far from you. NickT. - Chris Williams - 02 May 2007 Nothing to exiting actually. The main reason for the swap is that I have some "issues" with my existing engine that need to be resolved. So a standard 'D' block with slightly higer compression pistons, fast cams, volvo dizzy, Sort of a stage 1/2. Unfortunatly I can not afford a new exhaust at the moment but have installed all new studs for the future. Chris - NickT - 02 May 2007 A standard B28E engine from a volvo 260 estate will fit after swapping the sump over etc over. 170hp out of the box with high compression pistons, spark distributor, matching cpr/ fuel distributor etc etc. Sounds like a bhp project, good luck. If I can help let me know. NickT. |
