Clutch kit, part numbers - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 4 - Transmission - Manual & Automatic (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=16) +--- Thread: Clutch kit, part numbers (/showthread.php?tid=547) |
Clutch kit, part numbers - Chris Williams - 26 Apr 2007 A question for those who have changed the clutch in there cars.... I know Dan has been good enough to supply the part number for Motaquip clutch kits. However does anyone have the part number for the other brands; Valeo Etc Etc? As its sometimes easier to get other makes. Cheers Chris - bozzzydmc - 26 Apr 2007 © ![]() ![]() Rich Hutchinson DOC 365 VIN 1274 Richard <Richh11@...> wrote: For anybody thinking of replacing the clutch or doing work on the gear box, here are a few part numbers (and prices inc VAT) that may be useful: All bits apart from the crankshaft oil seal and clutch were extracted from a local Renault Dealer, I tracked them down to one of the Alpine boxes... Gear box rear gasket - 77 00 647 119 £9.04 (needed if you split the box) Input Shaft Nut - 77 03 040 031 £4.57 (needed if you split the box, is staked to the shaft and can't be reused) 5th Speed Shaft Nut - 77 03 040 028 £1.71 (also needed if you split the box, is staked to the shaft and can't be reused) Bellhousing to input shaft tube - 77 03 065 056 £1.85 (bog standard O ring, the most likely to leak) Bell Housing Gasket - 77 00 565 780 £3.74 (needed if you remove the bell housing to replace the O ring) Input shaft to tube seal - 77 03 087 084 £14.48 (need to split the box to replace this one) Release Fork Gator - 77 00 615 305 £18.05 (stops crud falling in the clutch, mine was split) Release Fork Grommet - 77 10 009 516 £0.79 (fits around the release fork pivot to keep the grease in, mine was split, worth replacing anyway) Reverse Light Switch - 60 01 001 318 £13.81 Rear crankshaft oil seal - VOLVO - 1218389 (behind flywheel. You need a 'special tool' to fit it - a bit of tube the right diameter) I got my clutch from GSF (As suggested by Stuart Dyke). It's a Valeo part no: 7701-466-774 that will get you the clutch, pressure plate and release bearing. Cost £113 inc vat. - bozzzydmc - 26 Apr 2007 soon to be added to the parts x ref list ![]() - Chris Williams - 27 Apr 2007 Cheers Mike ![]() Chris |
