ignition barrel problem - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 3 - Electrical (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=15) +--- Thread: ignition barrel problem (/showthread.php?tid=5193) |
ignition barrel problem - bttf brian - 10 Sep 2015 Hi After starting my D the ignition barrel has decided not to spring return to the "run" position. Does this mean that I need a new barrel? Any thoughts will be most appreciated Thanks Brian 4847 Re: ignition barrel problem - Chris Williams - 11 Sep 2015 Probably, I 'think' they are from a Rover SD1 IIRC. Chris |
