Reversing camera with Flux screen saver - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: OFF TOPIC TALK, BTTF, JOKES ETC (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=3) +--- Forum: Off topic talk, general chat etc (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=27) +--- Thread: Reversing camera with Flux screen saver (/showthread.php?tid=4924) |
Reversing camera with Flux screen saver - 88mph - 23 Feb 2015 As rear vision is so bad & my drive (rubble path) so tight. I've a cool idea for setting up a reversing camera but mounting the screen on the rear shelf below the rear window, you would have to turn to see it, which would be fine, but when camera not being used it could display a flux capacitor thingy. I've no idea how actually to do it but would be very cool. Advise please from you electronic whizz kids!
Re: Reversing camera with Flux screen saver - 88mph - 23 Feb 2015 Something like this...... http://www.ebay.co.uk/itm/18-IR-Reversi ... 231b583470 Screen has two input, so one from camera & then you'd need something to input the flux image & then someway to switch between them. Possible? Ideas? Re: Reversing camera with Flux screen saver - Chris Williams - 24 Feb 2015 Seems like a good idea, not sure how you could do it as I'm not the whizz kid your looking for! But if you get perhaps get a screen with a usb port and get a clip onto a usb stick maybe? Chris Re: Reversing camera with Flux screen saver - Dangermouse - 24 Feb 2015 Normally these reversing cameras are activated by a switch on Reverse gear, so that part should be fairly easy. I would think that you would have to have a series of images when not in use to reduce the risk of screen burn. Re: Reversing camera with Flux screen saver - 88mph - 24 Feb 2015 Ideally a moving image of the flux doing its thing, but yeah suppose it could flick to 'Plutonium depleted' or something. But how do I do it? :? |
