sticky throttle - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 1 - Engine (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=13) +--- Thread: sticky throttle (/showthread.php?tid=490) |
sticky throttle - johnomac - 06 Apr 2007 the cable on the pedal end sticks and takes a while to return up. Please please tell me i can just wd 40 it and not spend more money!
- Sirolf - 23 Apr 2007 Pull it out and replace it with a cable you can get at any motorcycle shop. - cineman - 23 Apr 2007 Maybe is too simple, but if it is a manual trans, check that the cable is in his correct way in the throttle, on the engine. If it falls down it can be sticky
- Guinney1971 - 23 Apr 2007 Phill got my new cable from B&Q - it was perfect for the job and cost about 32p a metre - you have to put a 'ferral' on the end though, but you can get them from any motor factors. You need to buy 4 metres of cable - the cable itself is just over 3 metres, but by getting 4 metres it gives you a bit of slack if you need it - plus also you can trim it gradually, rather then getting too short a piece. Hope this helps, - Daniel Shane - 24 Apr 2007 Sirolf Wrote:Pull it out and replace it with a cable you can get at any motorcycle shop. Hi There, Could you not use the DMCL logo as an avatar as it might give people the wrong idea. Many Thanks Dan Shane ex DMCL - bozzzydmc - 24 Apr 2007 As per request deleted due to copyright issues - Paul McKay - 24 Apr 2007 A fellow Delorean owner in Scotland
- bozzzydmc - 24 Apr 2007 so there is ! ![]() and vins so close as well ! - TheOriginalMrP - 07 May 2007 Yes, my throttle cable snapped at the pedal end today, fortunatelty I was only a few miles from home, and i managed to get back on tickover. Bodged it for the meantime, but I'm hoping your advice will sort it guys.... It is just the inner cable you change isnt it? Is it easy to thread through? And these "Ferrel" things, i assume its just a slide over cap that goes the pedal end to grip the linkage, and also stop the cable splaying out. And B&Q do it too do they? Bonus! Thanks in advance all Mr. P |
