Dash lights not working - Printable Version
+--- Forum: 3 - Electrical (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=15)
+--- Thread: Dash lights not working (/showthread.php?tid=4389)
Dash lights not working - airfireman1 - 29 Mar 2014
I have just fitted a new headlight switch from DMC, one of those new ones with a control box. It all works great and headlight and park lights work as they should. No dash lights are working, they used to. Checked that the rheostat had power and yes it has, the other side changes the voltage when you turn the dial but no dash or centre console lights. No power going to them.
Any ideas?. Is there a plug that may have come loose ?
Re: Dash lights not working - TheOriginalMrP - 29 Mar 2014
Hi.
Start here..
http://dmctalk.org/archive/index.php/t- ... fc21e2ce02
Hope this helps. .
Re: Dash lights not working - Chris P - 29 Mar 2014
Too technical for me, all that little lot!
Re: Dash lights not working - airfireman1 - 30 Mar 2014
Well after studying the wiring diagram and pulling a couple of relays, it works. Very happy with the results. Now to put it all back together.
Onto the next item on the list.
Thanks for the help, much appreciated.
